EPM.ISSU.RollUpgrdCncl
Description
The rolling reboot was canceled due to the specified reason. The system will most likely be left in a state that requires manual intervention to correct.
Remedy
If the rolling reboot was part of an In-Service Upgrade, the system is likely left in a state where some slots are running the upgraded software, and some are not. This condition must be fixed manually. Once the problem that caused the rolling reboot to be canceled is corrected, each standby slot that has not already been rebooted should be manually rebooted. Be sure each standby slot is back up and operational before rebooting the next slot. Once all standby slots have been rebooted and come back in-service, manually reboot the backup slot and ensure that it comes back In-Sync. The last step to perform a failover.
Severity
Error
Message Text
The rolling reboot was canceled due to an error: %reason%
Message Parameters
Name Type
reason String
